Can I set up a network?
Discussion in 'Desktop & Laptop Computers Forum' started by scrapbook, Dec 22, 2004.
  1. scrapbook
    scrapbook
    Jan 12, 2002
    7,411
    +550
    I currently have two pc's in the house and a laptop. All are currently connected to broadband via a wireless router.
    Is it possible to set up a network between the three computers to share files etc using the current hardware? or do i need to buy some more gizmos??
  2. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    Yes - you should be able to setup a network with what you have - in fact if they are all connected to the wireless network then they already effectively are. What operating systems are you using?
  3. chilpillphil3
    chilpillphil3
    Yep, If there using XP then its so simple. If not it gets a bit more complicated.
  4. scrapbook
    scrapbook
    Jan 12, 2002
    7,411
    +550
    wahoooo..yep all using XP. (Just updated the old actually from 98 - I really like XP - mahoosive improvement)
    Anyway - so what do i need to do / where do i start??
  5. aligebes
    aligebes
    Jan 2, 2004
    233
    Edinburgh, Scotland
    +3
    If memory serves, go to Control Panels and run the Network Setup Wizard, as you are wireless, if you have XP with Service Pack 2 there is a Wireless Network Setup Wizard.
    That should take you through the necessary steps, I think you may need to do this on each of your machines
  6. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,144
    41
    NW London
    +17
    You can do it on one machine and opt to ccreate a floppy disk that will set up all the other machines in the same way
  7. scrapbook
    scrapbook
    Jan 12, 2002
    7,411
    +550
    Ok will update the laptop with SP2 (other 'puters already have full version with it inclusive) and then give it a whirl.
    So how would the network work in real terms. For instance can I print something of from my laptop when the printer is connected to a PC without installting printer drivers etc? or do i still need to do that?
  8. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    if they're all running the same os then it will just use the driver from the host machine.
