Can I rewire my "scart to svhs" to "svhs to scart"?
Discussion in 'Cables & Switches' started by Tyler Durden, Aug 20, 2005.
  1. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,365
    Shrewsbury, UK
    +300
    I have got a soldering iron, but what do I need to do?
  2. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,365
    Shrewsbury, UK
    +300
    Well, can I?
  3. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    If the scart connector is the type you can open up easily, then no problem.
    Here is a link that shows you the pinouts http://www.acl.co.uk/pinouts.htm
    Look at pins 19 and 20
    Good luck and dont burn your fingers :)
    Mark.
  4. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,365
    Shrewsbury, UK
    +300
    Thanks very much for your help. Luckily I don't have to re solder anything because the pinouts in my scart connector can be unclipped and swapped over!
  5. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    +171
    That was easy then !
    :thumbsup: :thumbsup: :D
    Mark.
