Can I record from camcorder input?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Alan842, Jul 13, 2004.
  1. Alan842
    Alan842
    I have a question about camcorder inputs.
    I use a camcorder for videoing/coaching the sport of rowing.
    I have just bought a tiny wireless 'spy' camera which I would like to attach to the boat.
    It transmits to an AV Receiver which has a 'Video Out' red plughole (is this called 'composite video'?).
    I obviously cannot have a mains VHS player on the river, so it's got to be a laptop or camcorder.
    Is there a camcorder with a 'signal in' plug to match - the gadget came with a red male-male lead.
    Do camcorders record from input leads?
    Any help appreciated.
    'Woody' Alan Sherman coaching in London, UK
  2. Brian110507
    Brian110507
    First I'm very surprised about the red plug on the AV receiver for video out, the standard colour for composite video plugs is yellow.
    If it is a composite video out then you should be able to connect it to any camcorder having AV-in (note this is not the same as DV-in) - - Camcorders having AV-in are quite common but not all camcorders have this function.
    Check your camcorders specification if it says you have AV-in then a cable with a phono (RCA) connector on each end should do the trick, check also which buttons you have to press on the camcorder to record AV. but note that video in on your camcorder will be yellow. red and white are for audio.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,441
    Rainham Essex
    +2,470
    Yep, agree with Beejaycee. Many but not all camcorders can do as you want. Many more will have DV-in only so you will need to check the specs of any cam very closely to check that it does have AV-in as well.
    Assuming you have a cam with the AV-in all you ned to do is power it up in VCR mode (or whatever its called on your cam), not in the normal camcorder mode, and then as the name suggests you can just connect up an eternal camera and use the camcorder as a VCR.
    If you don't already have a camcorder and are looking to buy then let us know your budget and we will give some advise on which make & model(s) to go for.
    Good luck,
    Mark.
  4. Alan842
    Alan842
    Thanks for the quick response.
    I have an ancient Panasonic which doesn't seem to have an input. Earlier this year I bought a DVD camcorder which only has AV out (got fed up lugging TV, video deck, leads, mains plug etc to the club, now just need a portable DVD player).
    I'd be interested to know which camcorders can record from AV In, preferably without having yet another format, the Panasonic is VHS-C.
    Meanwhile, I'll test what the red plug does by trying to record to my VHS recorder.
    Thanks, Alan
  5. Brian110507
    Brian110507
    First I don't think you'll find a VHS-C camera having AV-in it was not a function available on those sorts of camera so - a new camera then -depends on how much you want to spend on a new camera - choose one in your budget and read the specification, every one I've read clearly states in it's spec "DV-in/out and/or AV-in/out" so you shouldn't have to much trouble choosing.
    If you read some of the other threads in this forum you will see that I strongly recommend DV in AND out so it's just a matter of looking for the AV-in bit in the spec.
