Can I record a web media stream?
Discussion in 'Music & Music Streaming Services' started by Nello, Nov 4, 2003.
  1. Nello
    Nello
    Anyone know if there's a way you can save a .asf stream from a website to hard disk? and maybe convert it to mp3 afterwards?
    must be something out there that can copy a stream?
    Cheers, Neil
  2. tomson
    tomson
    Jul 19, 2000
    1,918
    Berk'amsted
    +187
    I know of an app for the mac called Audio Hijack - it basically records any sort of sound, so it could be a live radio stream, a dvd soundtrack etc etc. There might be a PC version of it. Maybe.
  3. Nello
    Nello
    Cheers Thomson, I'll have a look for that
  4. mjn
    mjn
    May 24, 2001
    18,202
    Herts, England
    +5,216
    just do a line-out to line-in and record the analogue signal
  5. Nello
    Nello
    Sorry mate, can you explain that in dunce terms :confused: Straight from soundcard LineOut to soundcard LineIn? Didn't know you could do that.
  6. sdh500
    sdh500
    A longer way round would be to record it onto an audio cd-rw with a standalone cd recorder - (if you have one) - sound card line out to cd recorder line in. Then you just finalise the new CD and stick it into your cdrom drive and record it to your hard drive as normal (even converting it to mp3 at the same time if you've got that feature in your software.
  7. Kali
    Kali
    do a search for Streambox VCR, it does a great job at grabbing streaming audio.
