Can I plug speakers with XLR inputs directly into DAC
Discussion in 'Home Cinema Speakers' started by designforge, Jul 17, 2015.
  1. designforge
    designforge
    Mar 19, 2008
    5
    Hi, this may be a newbie question, I am looking at an improved audio setup from my PC and having been looking at DACs, would it be possible to connect something like a cambridge Audio DACMAGIC Plus direct to a pair of Active speakers using the XLR output? Would this work?
    Many thanks
    Neil
  2. Don Dadda
    Don Dadda
    Sep 20, 2007
    5,669
    London
    +730
    Yep
    How do you intend to connect the pc to dac - spdif or usb?
    There is or was a debate which is better but i personally am neither one or the other.
    if Jitter or such like is a concern to you, I suggest to do a little research for your circumstances.
    What's the format of the files being played? Flac is best but you could have some good quality mp3 (320kbps) that may sound just as or almost as good.
    You also may find that anything that were of poor or border line quality before, most likely will sound worse on the new setup. This is not the fault of the setup but the file being exposed more by the better setup.
  3. chaotiker
    chaotiker
    Mar 19, 2010
    27
    3
    +3
    That's the way I run it. DAC to Subwoofer (Adam Artist Sub) via XLR, from there via XLR to the Adam Artist 3. I'd make sure you get a DAC with a volume knob like my Teac UD-301. It makes life so much easier to just grab that and tune the volume.
    Be aware the bigger 501 can't regulate the XLR outputs with the volume knob.
  4. bluedroog
    bluedroog
    Nov 16, 2009
    3,380
    London
    +1,409
    Yes you can, I used my M-DAC to Event Opal monitors but preferred the sound with a valve preamp in the chain.
  5. TomScrut
    TomScrut
    Jan 11, 2012
    2,669
    Scarborough, UK
    +438
    I take it you have a volume control in the system somewhere (on the PC, in the DAC or the speakers)?
  6. designforge
    designforge
    Mar 19, 2008
    5
    Thanks guys, that's a huge help :)
  7. designforge
    designforge
    Mar 19, 2008
    5
    @Don Dadda - connected over USB, mostly FLAC playback but some 320kbps and older 192kbps MP3 files, although they're not really played as much. Great tip for the lower quality files, thank you!
