can i plug my ps3 into this.
Discussion in 'Playstation Forums' started by selighhh, May 4, 2007.
  1. selighhh
    selighhh
    hi
    can i plug my ps3 into sony HT-SS1100, the hdmi cable will go to the tv but what do i need to connect ps3 to this system. thanks
  2. smashie
    smashie
    Apr 20, 2006
    832
    great yarmouth OOOAAAR!
    +51
    an optical cable for sound mate and away you go..:thumbsup:
  3. jharri105
    jharri105
    May 4, 2007
    16
    With mine all i need is the hdmi lead and thats all.
  4. supahoops
    supahoops
    Nov 22, 2006
    585
    28
    +34
    I got the same amp and i thought hdmi from my ps3 to the amp would be sufficient but i get no sound :eek:
    so now i use hdmi to amp and a seperate optical cable for sound
    on a side note when i play blu ray discs on the amp menu it displays pcm is that the best setting for sound or should it be bitstream :confused:
  5. selighhh
    selighhh
    is the optical cable better or worse than hdmi for pluging the ps3 into sound system?
  6. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,158
    Bristol
    +9,898
    The Optical cable doesnt carry as much bandwidth as HDMI so probaley best to use HDMI.
    Also, HDMI is the only way to get HD audio if that helps.
  7. selighhh
    selighhh
    okay, the sony HT-SS1100 it has 2 hdmi inputs and 1 hdmi output, so will this work, plug my ps3 via hdmi into the sony HT-SS1100 and than have another hdmi cable running out of the sony HT-SS1100 into my hdtv, or won't the receiver handle visual input?
  8. supahoops
    supahoops
    Nov 22, 2006
    585
    28
    +34
    I tried doing this but found i got picture but no audio. So i had to spend more cash on a seperate optical cable from ps3 to htss1100, then it works fine.
    Not sure but I think u need a tru hd capable amp for hdmi to carry audio and picture from the ps3 to the amp.
