can i plug a cd player in to a p60amp
Discussion in 'TAG McLaren Audio Owners' Forum' started by donal_mac, Jun 23, 2005.
  1. donal_mac
    donal_mac
    hi guys i want to know can i plug my cd player in to the p60 pwer amp and miss out the p10 pre amp for better sound might sound strange to you but iam new to this so if you can help a newbie :rolleyes: that would be most kind of you.
    kind regards donald
  2. Tantalus
    Tantalus
    Aug 21, 2003
    289
    Aberdeen
    +3
    I'm afraid you need a pre amplifier in the loop to take the electronic signal from the CD and get it to the level required by the power section of the amp. If your CD player has a digital output, you would need a DA convertor in the loop also.
  3. roversd1
    roversd1
    If the cd has a variable output, yes you can connect direct to a 60P, but I would advise against it as you would get lots of loud pops and bangs if you did.
    Use the PA10 as it is a very good pre-amp.
  4. donal_mac
    donal_mac
    thanks for the help it is much appreciated from you gurus of hi-fi
