Quantcast
can i play ps3 in another room without moving console??
shelbi805
is there a way of playing the ps3 in another room without moving everything? bit like sky eye (just have to take the remote with you)
Foster
A long ass HDMI cable but other than that no you can't
next010
There are low latency wireless HDMI transmitters, normally they are very expensive pieces of equipment almost the cost of a PS3 itself but Dabs have a sale on one at the moment going for very little though how well it works is hard to say and the range on these units is not very good.
Foster
In other words don't bother xD
next010
Yeah but for £39 down from £239 it might be worth risking, however the other risk is the PS3 controller and the range on that.
Axum
Having a quick read of some reviews I wouldn't risk it, it's meant to work GREAT when the transmitter/receiver are in line-of-sight of each other up to about 10m but maybe more (picture/sound is near identical apparently), but doesn't work if anything in the way i.e. walls, cabinets etc...
Steven
Senior Moderator
Just buy a second set of HDMI cable and figure of 8 ac lead. Both can be had on Amazon for about a fiver, possibly with change depending on the length required
