Can I Pair my Denon 1905 with my Audiolab 8000A?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by scooby l, Mar 15, 2005.
  1. scooby l
    scooby l
    Jan 24, 2005
    187
    Chippenham, Wilts
    +3
    I have thought about bi-amping my front Monitor Audio S8i's, and have an old Audiolab 8000A stereo amp spare.
    Can I bi-amp this with my receiver to provide better quality?
    The older amp is obviously non remote, so do I have to adjust the volume by hand each time?, or does the receiver control that.
    Sorrt if I sound a bit green.............but I am.. :D
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Bi-amping isn't a good idea when you use different amps as they will most likely have a different gain, so when you increase the volume by e.g. 2dB on amp A the other amp might go up by e.g. 3dB.
  3. scooby l
    scooby l
    Jan 24, 2005
    187
    Chippenham, Wilts
    +3
    Cheers Reiner
    I may just leave well alone then...
