Can I mount my TV to this bracket?
deliairj
My landlord has left a TV bracket up for us to mount our TV to. I can’t work out how to do this though as the screws they left are too big for my TV and it seems like the holes in the back of my TV are too small for the bracket?
Is there any way I can make it work?
Jamie
Brackets like that would usually come with a bag containing a selection of bolts, spacers and washers so you can choose the right ones for your TV so it's certainly possible but not without obtaining suitable bolts etc.
Joe Fernand
AVForums Sponsor
Your TV User/Install Manual will usually specify the type of Bolt the threaded inserts on the TV take, usually pretty standard bolts you can pick up in any DIY shop.
Note on the pic of the slits on the hanging bar you can see the round mark where the steel washers you also require marked the paint the last time the bracket was used.
As @Jamie mentions brackets normally come with Instructions plus a bag of varying size bolts and washers, as a random example see.
Joe
