Can I mount a plasma on chimney breast with gas fire below
ALIEN1X
Established Member
I thinking of buying a plasma Panasonic 'VT50', can i mount this on a chimney breast wall with a active recessed open gas fire below?
This is the only placed I can put the 50 inch screen, as there is no vt50 42 inch this year?
Regards
Alien1x
mikej
I bet people do, but it's probably not advisable !
For one thing - plasmas like the VT50 can get quite warm and require cooling with fans. If you subject them to heat from below (any heat put out by the fire will rise directly in front of the screen) and behind (does your chimney breast get quite warm to the touch ?), then it may struggle to keep cool.
If you went for it, you'd have to make sure that any wall bolts needed for the bracket didn't break through into the flue, from a safety point of view.
ALIEN1X
Established Member
Thanks for the advise, guess your right,I will have do some replaning. Ah you say the VT needs fans, I know the screens get hot but fans being applied I never heard off?
mikej
lol - no, I mean that the plasma contains fans at the rear that try to get rid of the heat from within the TV itself.
Have you ever heard the fans on your PC or laptop working overtime when the ambient (room) temperature gets too hot ? I can only guess your plasma's fans would do the same when you've got the fire on below.
smarty
Established Member
QUOTE]
That's not actually correct (well, certainly not in my case).
Put the fire on and hold your hand against the wall above it, where you'd want the TV to be placed. See if it feels hot. Slowly pull your hand away from the wall. In my case, when I did this the area close to the wall was no warmer than the rest of the room (guess the heat radiates rather than just rising up) but pull your hand away and 8 inches or so from the wall it would start getting warmer. I guess how close to the wall the heat gets will depend on whether you have a mantle piece, how deep it is, the fire's output etc. Do you actually use the fire anyway? We never really used ours so I took it out in the end.
Our Panasonic Plasma was over the fireplace for about 7 years and never had any issues (although it was actually too high really - now it's lower it's much better).
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
