adacey
After finally moving into our own place last year I'm looking to address the long-overdue move away from TV speakers and would like to get a proper surround setup for our lounge.
The house is a late 20's semi and the TV wall is the common wall with the neighbors. So I want a good immersive experience, but I'm not planning to run the system at levels loud enough to annoy them.
The current room arrangement has a TV stand in front of the old chimney breast with my roughly 8-year-old 48" Sony flat screen and the sofa is against the other wall, which I know is not ideal.
Here's the current layout:
My thinking was to upgrade to a 55" LG G1 and mount it on the chimney breast. It's defunct so I think I could even manage to route the cables through the chimney to get a nice clean look. There are power sockets in the "alcoves" on either side of the chimney. Technically, the chimney is just wide enough that I could squeeze a 65" on there, but it would leave such a small gap on either side I think it might look a bit out of proportion.
Ditching the TV stand could allow me to get rid of the current TV stand and pull the sofa into the room about 30cm or so, allowing for a console table behind it. That would give me something like the following layout:
Now my big question is the number of channels and speaker selection. Where the room is basically just 3.3 x 3.4m with about 2.65m ceilings is this a big enough room to handle a 7 channel setup or would I be better off just sticking to 5 channels?
I've not listened to anything yet but based on reviews, my thoughts were maybe to go with a Dali Oberon 1 package and add a pair of Oberon on-wall speakers to get up to 7 channels. Or, possibly go all on-wall for the surrounds. Then possibly the Dali Alteco speakers mounted on the chimney for Atmos. I was thinking of the bookshelf-sized system as it wouldn't take up as much space and I've been considering putting built-in cupboards in each of the alcoves, which the speakers could sit on top of. For the center channel, I'm at least fortunate that there is a convenient shelf in the chimney where the fireplace was that's high enough to clear the coffee table, although I'm guessing I'd want a front-ported speaker for such an enclosed space?
For the receiver, probably a Denon 3700H or 4700H, I kind of like the idea of having a bit more head-room for expansion if I could ever move to a 7.2.4 setup, although again, I'm not sure if I'd be able to position the rear Atmos speakers in a good spot. Maybe up high on the walls to the left and right of the sofa? Similarly, would I get much value in adding a second subwoofer to this setup? And where should I place them?
The budget is a bit flexible, I realize on the low-end of the budget I could be under £5k for the TV, receiver, and a 5.1.2 setup. I'd be willing to go up to about £8k if I could get a 7.2.2 or 7.2.4 setup but I'm not sure where that extra money would get me the best bang for my buck.
