Can I make my Sky + remote operate the volume on my amp?
Discussion in 'Sky Digital TV Forum' started by Unlight, Feb 1, 2005.
  1. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Hey guys,
    As I havent got any internal speakers on my plasma, its kind of annoying to have to keep two remotes at hand to operate channels and volume.
    Is there any way I can program my Sky + remote to control the volume on my Denon 2805, while still being able to switch on and off my plasma?
    Thanks, any info much appreciated!
  2. Too Tall
    Too Tall
    May 20, 2002
    538
    Milton Keynes
    +8
  3. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Tried that, but after trying both Denon codes, the led doesnt blink twice to say the code has been recognised! :(
  4. bbasra
    bbasra
    Sep 15, 2004
    1,663
    48
    Hounslow
    +43
    nor does mine.... what shall i do....
    and the hummer.co.uk website is down?
    does this mean my remote is old?
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    It's not down, it has been changed.....
    www.humvee.co.uk/sky.htm
  6. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Anyone any insight into this?
  7. bbasra
    bbasra
    Sep 15, 2004
    1,663
    48
    Hounslow
    +43
    got mine to work with my sky+ pace v1 and denon 3805.... you need to use the code 1388.
    Press TV
    Press and Hold Select and 0 untill the led blinks twice
    key in 1388
    the led should blink twice
    press left arrow and the amp should switch off
    also, if you press tv, hold down select and 1, and press tv again, you can control your av amp volume which is perfect for me.
    hope this helps!
  8. Unlight
    Unlight
    Jan 6, 2003
    1,524
    38
    Belfast
    +9
    Hi mate!
    That worked an absolute treat - thank you so much!
  9. bbasra
    bbasra
    Sep 15, 2004
    1,663
    48
    Hounslow
    +43
    @unlight, glad it works! took some surfing but found the answer.
    www.humvee.co.uk/sky.htm should be updated with this code for denon.
  10. pa 28 driver
    pa 28 driver
    Have tried for month or so now to get my plus remote control Sony amp, tried all the sony codes as per the excellent www.hmvee.co.uk but with no joy.Anyone able to help please, cheers
