can i make my own sky digital box for mce?
Discussion in 'Microsoft Windows' started by weebroonieuk, Mar 19, 2006.
  1. weebroonieuk
    weebroonieuk
    Oct 30, 2004
    177
    16
    would it be possible to receive skys digital signals through my pc with a satelite card as i want everything inside mce as i love its interface and ease of use
    if you need a sky card then i take it there is a card reader that could be plugged into the satelite card or pc via usb
    also would the guide work the same ?
    cheers Gordon
  2. stlic
    stlic
    Feb 17, 2004
    769
    +19
    Short answer. No and No. :(
    Reason: Sky encrypts their viewing card.
  3. weebroonieuk
    weebroonieuk
    Oct 30, 2004
    177
    16
    bugger what are the free to air channels like do i get anymore than u get with dvb t signals , and are they any stronger ?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    you get more but not all the DVB-T are free on DSAT
  5. Ch0pper
    Ch0pper
    Mar 31, 2005
    246
    +3
    Just plug a digibox into your TV tuner input (make sure it's an analogue).
    I use 2 x Grundig GDS3000 boxes. You can hook up using the S-Video out on them then. Nice picture and it's like Sky+ as you can record 2 channels at the same time :)
  6. Kramer
    Kramer
    Moved to MCE forum.
    :smoke:
  7. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    Alternatively the answer you probably wanted to hear. Yes & Yes.
    You can use the Technotrend TT S-1500 budget DVB-S card with their BDA driver & MCE tools (That fool MCE that it's really a DVB-T or Freeviw card) fr all the Free To Air Channels.
    You can also use the optional CI adaptor with a T.Rex CAM (formerly known as a Dragon CAM) loaded with the latest firmware (3.31). This enables Sky to be decoded on your PC with a legitimate Sky card (could be a Free TV card that adds just C4, five & Sky Three to all the FTA channels). This works seemlessly with the Technotrend Media Center application. Using this within MCE is working mostly. You can watch & record within MCe all the Sky channels that you are subscribed to. The one outstanding problem is that unattended recordings that require changing to a scrambled channel fail. Technotrend apparently are aware & should have new drivers 'Real Soon Now'
    The one caveat with using the T.Rex CAM is that AIUI Sky could do something to their encryption that would mean that the CAM no longer allowed decryption with a legitimate card. However it has been working for the last 9 months so you pays your money & takes your choice.
  8. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    I would reckon they are on to it. Expect them to do something immediately prior to their high def box launch or the World Cup.
  9. MacBurp
    MacBurp
    Aug 9, 2005
    262
    28
    +22
    Can you provide some links for this please? The Technotrend website is less than forthcoming on this development.
    thanks,
    Paul
  10. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    Why would they do something except for sheer bloodymindedness? They are not losing any money in fact the contrary may be true. TBH just getting the FTA channels within MCE in better quality than Freeview is fantastic.
  11. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Sheer bloodymindedness can be the difference between a succesful company and a failed one! Remember that even as a free to air viewer you are still potentially a source of revenue to them. That may not be the case if you use a pc rather than a set top box. They will close the loophole when they become aware of it, and will choose to do so at a time that gives those that would try and work around it minimum time to respond.
  12. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
  13. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    The FTA channels are always available you don't need a card or Sky digibox. You can use a PC or a regular satellite receiver. In both cases you can have Sky+ functionality without having to pay 10 pounds per month.
  14. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Sky don't get a chunk of license money, and getting that sattelite in the air costs a lot of money! They don't have a problem with you staying with them for free to air using a set top box becuase they can still potentially sell movies and special events. They lose that potential when pcs or non Sky boxes come into the equation.
  15. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    True & Sky may not like it but there is still no way that Sky can stop you watching BBC1/2/3/4 ITV1/2/3/4 plus a bunch of other channels on a PC or non-Sky STB.
  16. MacBurp
    MacBurp
    Aug 9, 2005
    262
    28
    +22
    sky are trying to protect their rogramming from hackers. That people who don't pay their subscription, and people who want direct access to the best quality programming so they can put it on bittorrent. Sky (and every other broadcaster and content owner) are paranoid about this - thats why they fight the CAM users.
    This must be an issue that CAM users face regularly - this must be a solvable issue that we can only discover by venturing into the satellite/CAM world.
    I'm going to dig into these sites over the days/weeks to come;
    http://www.satellites.co.uk/php-bin/forum/index.php
    http://www.duwgati.com/uk/index.htm
    while we wait for the next release of the Technotrend BDA drivers.
    I'm a Telewest custoemr myself, but would definitely go to Sky if we can crack this solution. Its not fit for purpose yet IMHO.
    regards,
    Paul
