Can I keep my old dish?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by dazza74, Jun 12, 2009.
  1. dazza74
    dazza74
    Aug 24, 2006
    13,037
    +1,394
    Having Sky HD installed on Tuesday and I'm wondering whether I'll be able to keep the old dish, do they normally treat it as a new installation and put a new dish up with the two feeds?
    I only ask as I've an existing freesat HD box and seems a lottery over which Sky HD box you get as to whether you can pickup ITV HD currently.
  2. kenedin
    kenedin
    Aug 19, 2008
    1,719
    Edinburgh, Scotland
    +312
    They may not put up a new dish if the present one is serviceable. They'll certainly install a quad LNB and you'll still be able to keep your Freesat box hooked up.
    Of the three box types currently being installed from new ( Samsung, Amstrad & Pace ), only the Pace has been updated with the new EPG/OS. The others are waiting their turn, hopefully in the next few weeks. The new software will enable you to manually add ITV HD. Lots of threads on this in the Forum here.
    Whichever box it is, make sure the installer performs a software update, and pairs the box with Sky so that all the Sky+ functions work, and you get all your subscription channels.
  3. RostokMcSpoons
    RostokMcSpoons
    Mar 1, 2005
    273
    Milton Keynes
    +8
    My dish was replaced (without me asking)... but he re-used the old arm. So I've got the *just* the dish, and the old quad LNB sitting in my garden. Is it worth anything?
  4. wellfan
    wellfan
    Jan 1, 2007
    320
    28
    Lanark
    +27
    Worth absolutely hee haw. Bought on ebay, etc for less than a fiver each!!!!!!!!!!!
