CAn i just buy a USB wireless adapter to get online?
Discussion in 'Xbox Forums' started by clarky78, Dec 31, 2006.
  1. clarky78
    clarky78
    Nov 8, 2004
    1,918
    Helsinki, Finland
    +43
    I have a wanadoo/orange wireless router upstairs and just want to connect my xbox to it wirelessly.. I was amased the 360 isnt ready for this, but can i just plug in a usb dongle adapter thing and setup my IP details for it to work? I can't see why not, but everyone goes on about these gaming adapters which to me seem like overpriced ways of doing the same thing but over ethernet instead.
    Any ideas people?
  2. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    buy the official one,is the only thing to do,unless you want to go and get a bridge or suchlike,but its not worth it,just stick with the official one.
    speeds are great and no problems in a year of owning mine at all.
  3. Br0ken
    Br0ken
    Jun 13, 2006
    10,469
    localhost
    +1,314
    Also agree with rottenfox.
    The official adaptor is the only one that'll work with the xbox, unlike as you said going down the other route. Mine's worked fine since i bought it a few months ago too.
    As for why it isn't built in, i guess it was just one of the ways to keep the cost down for the unit, a bonus for people that have the console wired to their network.
  4. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,958
    2
    Manchester
    +4,473
    FAQ Q1.4 :smashin:
    It's good that people have the choice to buy it or not as opposed to having to pay for something they don't want...?
  5. clarky78
    clarky78
    Nov 8, 2004
    1,918
    Helsinki, Finland
    +43
    That official one is more than a bridge! Whats the point in that!
    So even though my 360 is essentially a pc with a HD i can't install drivers onto the HD to run a 15 quid adaptor? That sounds more like a scam than an issue with hardware limitations. Well looks like a bridge is my only option then... Or i move my router downstairs and by an adapter for my pc..
  6. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,958
    2
    Manchester
    +4,473
    The official MS wireless USB adapter is just a bridge that requires no drivers. And the 360 operating system doesn't support drivers. Would you prefer the 360 shipped with Vista and called itself a PC?
    The fact that applications aren't handled in the same way as traditional OSs means its cheaper leaner and less prone to security risks.
  7. DragonOfSilver
    DragonOfSilver
    Dec 23, 2005
    1,085
    48
    +73
    it is not a bridge, its just a specific a/b/g wireless dongle that has the necessary driver inbuilt into the 360 kernel, or stored in firmware, depending how they've done things. Due to their business/security model, they do not allow anyone else to write drivers for the 360, so yes, if you want wireless, you need either the official dongle, or a seperate wireless bridge device to hook upto the wired port.
  8. jason g
    jason g
    Jan 8, 2006
    15,997
    Theatre Of Dreams.
    +3,702
    so u just buy the ms adaptor, xbox live account and u r away right?:D
  9. Br0ken
    Br0ken
    Jun 13, 2006
    10,469
    localhost
    +1,314
    Right :D
  10. ukkev2000
    ukkev2000
    Apr 12, 2004
    1,027
    48
    Hampshire
    +51
    No, you've lost me there, the official one is a what? A WiFi adapter? Yes it is.
    How do you come to that conclusion?
    A PC is a fixed architecture running a x86 instruction set CPU - how is that essentially a 360? How is the 360 the same architecture as a PC? Memory addresses, interfaces, driver layer?
    They are both computing devices but so is an Apple Mac, Acorn Atom, Sun workstation. None of those will work with your £15 cheapo no-name PC wifi dongle either.
