Can I integrate a Samsung Soundbar with a mini amp?
Discussion in 'AV Receivers & Amplifiers' started by audiomike, Jun 21, 2015.
  1. audiomike
    audiomike
    Jun 21, 2015
    4
    NY
    I have installed a Samsung Soundbar (HW-F355) and linked it via optical cable to a wd player. It is working well and comes on auto as soon as it senses input from the wd player. The problem is, I want to be able to have an aux in as well, and the soundbar is kind of inaccessasible, so wanting to put a mini amp for an aux-in and primary volume control between the wd player and the soundbar. I want to link the mini amp via optical cable so that I still have the auto-on feature on the soundbar. Just wondering if this is possible, and also amps that people would recommend. Sorry total newby question probably! Thanks.
  2. Don Dadda
    Don Dadda
    Sep 20, 2007
    5,669
    London
    +730
    You will need some sort or pre-amp or a simple mixer that will enable you to control the volume externally from the WD Player.
    However, there is a WD Player App available for IOS and Android devices which has a volume control and It works decently enough with my WDTV Live player. I seldom use it though,
    Which WD player do you have?
