Can I increase Freeview Signal Strength
Discussion in 'Freeview & YouView' started by shoehorn, Aug 24, 2005.
  1. shoehorn
    shoehorn
    Jul 2, 2003
    1,610
    The Garden of England
    +32
    I've just moved house and the signal strength on my Pace Twin is showing 20% (on both tuners) - some of the channels are "jumpy".
    The box is connected to an external aerial on the chimney and I was hoping that the signal strength would be better than this.
    So....
    Should I get a new aerial put up and if so,
    - how much should it cost (roughly)?
    - what could I expect the signal strength to be (or what should it be)?
    - is there a national company that is recommended, or will the local fitters be just as good?
    Thanks for any help / answers.... :)
  2. crobo
    crobo
    Mar 10, 2004
    3,175
    83
    +117
    We just had Freeview installed. There was no reception with the preexisting old aerial but the local fitter I contacted insisted a new one would work. He was right but because we are in a poor-reception area and wanted to have Freeview upstairs too (which kinda halves the signal) he used a 10-ft extension pole on the aerial to boost the signal. This pushed the total cost to about £150.
    Apparently the old aerials are not too good for Freeview.
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    If the aerial is an old installation, it's probably wired with single-screened cable (braid but no foil). You might need a bigger aerial too. Most reputable aerial installers will give estimates.
  4. wyndham63
    wyndham63
    My folks had the same problem when they moved house recently.
    The aerials in the loft weren't powerful enough so they spent a very reasonable £125 for a removal of old wiring from a redundant Sky dish and had a brand new aerial, extension pole and all the new wiring and fitting done with new extensions throughtout the house.
    Phone around your local suppliers and get estimates.
