Can I improve the signal on my HD box?
kyle286
My box is in my bedroom which comes off a splitter downstairs up to my box through a coax cable. But my signal is 76% max, Can I improve this in any way or any devices I can buy? Its a long cable which I dont want to replace. Thanks. :thumbsup:
PhilipL
You don't say if you have any problems with reception, such has freezing pictures or drop-outs?
If not, you don't need to do anything. Picture quality on Freeview doesn't change with signal strength, so even if you had 100% signal level or 10% signal level, providing it works, the picture quality is identical.
Hope that helps.
Regards
Phil
Gavtech
Administrator
...and if that 76% refers to signal strength rather than quality then it is an ideal figure.
Neither too strong nor too weak, either of which can cause problems.
kyle286
Hope that helps.
Regards
Phil
Thanks lads, but its a eurovox ex7000hd and the picture lags when the signals bad. Thanks.
