can i improve signal on wireless network
Discussion in 'Networking & NAS' started by hammy2891, Sep 10, 2004.
  1. hammy2891
    hammy2891
    is there a way to improve the signal on my wireless network without moving my htpc,i am using a belkin modem/router & belkin pci card any help would be appreciated from you guys :lease:
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,277
    Manchester
    +762
    Does the Belkin modem/router have an external antenna ?
    If it does you could get an antenna for it with more gain .
    If the positions are always fixed, you could get a highly directional aerial (yagi or "cantenna" , the latter being quite easy to self construct).
    Same applies to the PCI card - you may be able to add a pigtail and better antenna to it
    What is the full model number of both pieces of WLAN kit ?
    Chris Muriel, Manchester
  3. hammy2891
    hammy2891
    both modem/router & pci are 802.11g and yes the pci card has an antenna but it cant be extended to be put in a more receptive area.is there an extention cable you can get using the same card and aeriel?
    only set up the network tonight so i haven't really tried any other positions yet,the htpc can't be moved that far anyway.
  4. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,277
    Manchester
    +762
    Please state the model of your PCI card and router.
    A quick Google search seems to show an external antenna connector on the F5D7000 PCI card.
    Judging by its size I would expect it to be a reverse SMA
    type (RP-SMA).
    If it is, you should be able to unscrew the antenna and connect a better one.
    Chris Muriel, Manchester.
  5. hammy2891
    hammy2891
    i'm in work so i hope this is right
    pci is f5d7000uk
    modem/router is f5d7630uk4a
    it does have a aeriel you can unscrew so i would have thought an upgraded aeriel could be a possibility
  6. DaveP
    DaveP
    Out of interest: Are you asking this question because you cannot connect wirelessly? I'd be surprised if the range isn't satisfactory for you needs.
    I just wondered, when you say "only set up the network tonight " whether you had the network configured correctly?
    Dave
  7. groovyclam
    groovyclam
    Mar 28, 2004
    202
    Belkin's own website shows this add-on antenna:
    link
    This is their whole 802.11g product range:
    link
    There could be third party cheaper antennas, though, the connector is an SMA reverse male connector.
  8. hammy2891
    hammy2891
    just found that link as well.i think i'm gonna have to spend ahother £25
    the reason i get such a bad signal is i have the htpc in a spare room upstairs which is part of the extension,it has 15" walls,a concrete floor and couldnt be any further away from the router. :hiya:
  9. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,277
    Manchester
    +762
    Yes, you have the card that I quoted in my last post.
    You could buy a short pigtail (e.g. from www.solwise.co.uk) to adapt from the RP-SMA socket to a standard N-type or SMA (non Reverse-polarised) connector.
    Then you could build a cantenna. I built 2 of these and they can be knocked up in hlaf-an-hour or so.
    A Google search for "cantenna AND build" gets lots of hits.
    I tested mine the other day (using a laptop with Buffalo PCMCIA WLAN card and Netstumbler software).
    I am getting around 14-15 dB gain.
    Here's a UK website with some cantenna info :
    http://www.nodomainname.co.uk/cantenna2/cantenna_mark_2.htm
    Whisky tins, large SMA baby food tins and the like work quite well.
    Mine use a Fox's cookie tin (similar dimensions to whisky tin) and a Nescafe best beans can.
  10. The Dude
    The Dude
    May 21, 2004
    6,549
    Beverley, East Yorkshire
    +2,968
    if you've got a concrete floor to contend with I'd go for for something like the
    NET-WL-ANT010PN from www.solwise.co.uk
    you can get right through 2 houses with one of these so should do the job :devil: , you'll also need the adapter cable PIG-RSMAPNPLUG100 if you choose this option..
    Would be fun to try the homemade option first though, depends how much you like tinkering...
  11. hammy2891
    hammy2891
    thanks for all the info guys great stuff.think i'll try the belkin extension aeriel in the earlier link first and see how i get on with that before i try anything more drastic. i will let you all know how i get on with it when it arrives.
    by the way i have downloaded sp2 and it seems to have improved the signal a bit but not enough for a decent data transfer speed,don't know if that was a coincidence or what
  12. groovyclam
    groovyclam
    Mar 28, 2004
    202
    Hammy, before you spend any money - have you tried changing the wireless channel number of the router from the default and try some other values ?
    Sometimes you can improve reception by trying other channel numbers.
    It's in the "CHANNEL and SSID" link on the left of the router configuration html-page. Use the "Wireless channel" drop-down and try some other values. You will probably have to reboot the router for the change to take effect.
  13. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,277
    Manchester
    +762
    Good point that.
    Results can be affected by other local 2.4 GHz ISM band users' transmissions - like other local WLAN users or APs, bluetooth gear and DECT phones.
  14. hammy2891
    hammy2891
    great idea ut how do i get to the "router configuration html-page"if its the address 192.168.2.1 i just get aol search up with loads of sites,which site is it ? most sites wont even open ! :blush:
  15. groovyclam
    groovyclam
    Mar 28, 2004
    202
    You are on the right tracks.
    I think the default for a Belkin is 192.168.1.254
    Is it not in the manual for the router ?
    Go into Control Panel, Network Connections and you will see an entry/icon for your PCI wireless network card.
    Click on it to open the "Staus" box and then click on the "support" tab.
    There will be an entry for the IP of the PCI card in your PC and the router will have the same first three IP numbers but the last number could be anything between 0-255
    So if you see your network card has an IP of 192.168.1.7 then the wireless router will have an IP between 192.168.1.0 to 192.168.1.255 ( except 7 because that is your network card's IP )
    If you can't find the IP in the router manual you will just have to try to http:// to all the different combinations and one will work. When you find the right IP -> WRITE IT DOWN SOMEWHERE!
    You may also be asked to input a password to change the channel number. I think the default password is blank for a Belkin router so just leave the password box blank and click "submit". If you or someone has changed it from blank and you don't know what it is, then there may be a procedure in the manual to reset the router to factory defaults BUT THIS MAY SCREW UP YOUR NETWORK AS I HAVE NO IDEA OF YOUR EXACT SETUP - if you do this and end up with no wireless connection you will be stuffed and have to do a complete de-install/re-install of your wireless networking.
  16. hammy2891
    hammy2891
    thanks for the advice but i think i'll wait and try the new aeriel
    just found these on ebayAERIELSdownload the catalogue, if any one is interested in getting one as well
  17. hammy2891
    hammy2891
    received the aeriel tues but i've been on a course all week so unable to get back to you guys sooner.now all up and running and what a difference can't believe moving the aeriel made this much difference.have now gone from a very low signal (sometimes none at all) to a very good signal with no drop off of connection at all "well happy" :clap:
  18. MikeTV
    MikeTV
    Feb 1, 2003
    7,782
    Ealing, London
    +842
    My Belkin wireless router uses 192.168.2.1 by default, but I'm not sure of the model.
