Can I go freesat
Discussion in 'Satellite TV, Sky TV & FreeSat' started by josephobrien200, Jun 13, 2009.
  1. josephobrien200
    josephobrien200
    Sep 10, 2008
    100
    Birmingham
    +3
    Dear All
    This house which I bought 3 years ago has a satellite dish attached. Im presuming the previous occupants had sky and took the set top box with them.
    Do you think I could buy one of those freesat set top boxes from argos and use the current dish? Do you think I might be able to get away with a HD freesat box to go with my HD telly?
    Ive seen freesat boxes starting from about £40 in argos (SD). HD ones are double, at least but might be worth it if i get a nicer picture.
    Ive just bought a Bisg 250GB topuptv pvr s dont need freesat pvr.
    all the best
    Joe
  2. Member 354643
    Member 354643
    Feb 12, 2009
    1,055
    48
    Reading Berkshire
    +92
    Yeah shoul be fine as log as the dish is still on the satellite even if its moved or needs a new lnb its pennies
