can i get freeview with indoor aerial?
D
durain
live in a flat and the TV reception on the wall (communal aerial) is really bad. cant have outdoor aerial so only option is indoor aerial. is there any quality indoor aerial that will do the job to receive freeview?
p/s do have sky but would prefer freeview :)
JayCee
Best idea is to borrow a freeview box and try it.....if the signal strength is good in your area you may get away with it.
jenic
I can use an indoor aerial with no problems and it is only a cheap box and aerial. Although you can see the mast with no interruptions but the window and about 20 miles between me and the mast.
