Can I get decent FM reception from a TV aerial?
Discussion in 'AV Receivers & Amplifiers' started by broona, Sep 10, 2005.
  1. broona
    broona
    Aug 26, 2004
    5,595
    Hexham
    +684
    I've got a TV aerial lead coming through into my living room from an outside aerial, but not connected to anything, as I solely use Sky+ so have no need for analogue TV. Can I plug an extension cable into this and connect it to the back of my FM tuner on my separates system, or is there more to it than this? I'm currently using a dipole t-shaped aerial, and it's pants, just want some improvement on this for not a lot of outlay, and if this would work, it'd be the simplest solution for me. Thanks. :smashin:
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,383
    Somewhere in South Yorkshire
    +5,770
    Probably not, unless you are in a really strong signal area; the elements on a TV aerial are optimised for UHF frequencies. VHF requires longer elements.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    I no longer have a radio tuner in my system, but I did previously have a Denon 3802 with radio and that was fed from my TV aerial (loft aerial split for Freeview & FM radio) with no problems. I am however in the London area where we do tend to get strong TV & radio signals. I would therefore suggest that you give it a try and see if it works. If not then just replace the TV aerial with an FM aerial, but useing the same coax cable to connect it up.
    Mark.
  4. broona
    broona
    Aug 26, 2004
    5,595
    Hexham
    +684
    Thanks for the replies, for the sake of a fiver for the wire and plugs, think I'll give it a go, not a lot to lose! :smashin:
  5. shodan
    shodan
    Dec 11, 2001
    11,553
    shoeburyness
    +6,450
    I use it and it works a charm! Fantastic reception for FM!
  6. broona
    broona
    Aug 26, 2004
    5,595
    Hexham
    +684
    Yes I can! Bought a TV extension kit from Poundland for a fiver, connected it up, perfect (well 10x better than the aerial I was using before). :thumbsup:
  7. Guy10
    Guy10
    being a big fan of Dom Jolly and the Trigger Happy TV series, I remember the sketch where he goes into the "Pound Shop" and keeps asking "how much is this?"...to which the shop assistant, getting more and more agitated, keeps saying "It's a pound"".....so I'm a bit worried that you went into poundland and paid five pounds for something....
    ....but I guess if it's 10x better...you got the better part of the deal
    (no flames please - a late night attempt at humour!!)
  8. broona
    broona
    Aug 26, 2004
    5,595
    Hexham
    +684
    Good point, it was 'Pound Stretcher', not 'Poundland' or 'Everything's a Pound'!!! :rotfl:
  9. guli
    guli
    Sep 3, 2004
    412
    16
    You said Poundland :D :D
  10. broona
    broona
    Aug 26, 2004
    5,595
    Hexham
    +684
    I know what I meant!!! ;)
    PS, Purely Belter does it better than Dom Jolly! :D :rotfl:
