can i get 2 antenna plugs in my tv? i am using a Sagem Axium. pic of the back of the tv URL=http://img241.echo.cx/my.php?image=101366xp.jpg]http://img241.echo.cx/img241/4353/101366xp.th.jpg [URL=http://img241.echo.cx/my.php?image=101366xp.jpg][IMG]http://img241.echo.cx/img241/4353/101366xp.th.jpg[/URL] [img=http://img241.echo.cx/img241/4353/101366xp.th.jpg]
Yes, what you need to get is a coaxial "Y" Splitter available anywhere that sells electrical accessories
karan_thakkar, Although the "Y Splitter" may work to some extent, be aware that you could have problems. Apart from a reduction of signal strength, you'll effectively lose the advantages of the directional aerials and so may get interference. Still the splitters are very cheap, so it's worth a go! Good luck. (Oh yes, Welcome to the Forum. )
YAHOO!! THANX SOOOO MUCH WAT IS THAT WIRE CALLED I CAN CONNET MY COMP TP MY TV WHILE IT IS CONNECT TO MY COMPUTER
do you mean connect your PC to your TV as well as your monitor? YES any relation to Paras? NO but WHO, WAT, HOW, WHY?
then to have both attached you need a 2:1 VGA switch or DIstribution AMP (DA) if you wnt both on at same time, will be limited to running same res on both which may cause an issue
