Can I fit ssd to entry level iMac (500gb model)
sisko
I bought an entry level iMac just before Xmas. I know on the Apple website there are no options for a bigger hdd nor to fit an ssd, but would it be possible to fit an ssd?
Is there a spare bay for an ssd in the entry level model!
Matt_C
You would need to fit it as a replacement for the current HDD; there aren't any secondary bays
sisko
Thanks for the info; I wasn't sure if there was a secondary drive bay.
So much for that idea.
Matt_C
Why "so much for that idea" - you just remove the current HDD, clone it it to the SSD, and fit the SSD in it's place. Simple.
bpsmith
Doesn't the current iMac have a different type of hard drive connector, thus blocking the figment of replacement drives like you could before?
Similar threads
LG CX 4K OLED TV Review: The best TV of 2020?
