Paddy O Dawes
Can I fit a subwoofer to a standard type amp, with only standard L&R speaker connectors? I was told I could connect a subwoofer to any of the line out sockets (tho' I'd have to make any volume adjustments on the subwoofer itself).
Assuming that's right, is the line out you can see here (on the bottom) the right one to use?
(It's an old Harmon Kardon system, with all the components brought together and feeding into the one 'Main in' pair you can see next to it.)
I'm guessing I'd need an active subwoofer.
Thanks for any advice.
