can i do this?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by beachboy, Nov 14, 2004.
  1. beachboy
    beachboy
    1 Plug my AV Hi8 into a DVD Player/Writer
    2. Record the AV to DVD
    3. Load DVD (step 2) into my PC MsXP HD
    4 Video Editing SW on my XP PC
    5. Edit and burn a new DVD from HD
    Can I do this and if so what format must the DV recording (output step 2) be and what low/med. end DVD Player/Writer recommendations can be made.
    Essentially I want to get the film into/out of editing sw on my laptop avoiding a new wi-fi port,
    Thanks for learned knowledge in advance.
    BB
  2. johnjackthom
    johnjackthom
    Sep 20, 2001
    748
    Northumberland
    +284
    If you want to convert analogue video for accurate editing on a PC the DVD recorder route is not ideal. You will end up trying to edit a highly compressed Mpeg2 file, probably with AC3 audio, which many editing programmes have problems with.
    A better method is to use an Analogue to DV converter which is then connected to the PC by Firewire, allowing a straightforward transfer into editing software (same as if you were using a DV camcorder).
    I suppose your investment depends on whether you will be doing this often enough to justify the cost (around £150 for the basic Canopus one-way convertor, ADVC55)
    Take a look at www.sirentechnology.co.uk/ :smoke:
