Can I do this with a Freeview box?
Discussion in 'Freeview & YouView' started by fatmarl, Aug 13, 2005.
  1. fatmarl
    fatmarl
    Mar 9, 2005
    14
    3
    At the moment I only receive terrestrial TV. I have a VCR and DVD recorder. The way I have things set up at the moment, I can, for example, record BBC1 on my VCR, BBC2 on my DVD recorder and watch ITV all at the same time. I am thinking of getting a Freeview box. Would I be able to have a similar set up to my present one? Any advice would be appreciated.
  2. nig28
    nig28
    Yes, If you have 2 scart sockets on all your pruducts, connect them via scart.
    TV > VCR > DIGIBOX
    TV > DVDR > DIGIBOX
    Nigel
  3. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
    Yes but, unless you use analogue (until it's switched off) you'll need a Freeview box for your TV viewing and another Freeview box for recording. Connect them both to the aerial via a suitable amplifier. (You can try an ordinary splitter but it will probably lose too much signal).
  4. cerebros
    cerebros
    Dec 27, 2002
    1,293
    48
    Leicester
    +29
    I assume you mean would you be able to record 2 channels from the Freeview box on both the VCR and the DVD recorder at the same as watching a third Freeview channel on the TV. The simple answer is no, as a standard Freeview box only contains 1 Feeeview tuner.
    To do something similar to what you do now you would either have to:
    1) Buy 3 Freeview boxes and dedicate one to the VCR, one to the DVD recorder & one to the TV - this has obvious problems with regard to needing to find space for 3 more boxes, as well as buying different brands so that the remote codes (hopefully) don't clash.
    2) Replace your TV, VCR and DVD recorder with models with built-in Freeview tuners. Obviosuly the problem here is the expense.
    3) Buy a twin-tuner Freeview hard disc recorder. Using this you could watch one channel on your TV while recording another to the hard disc. Should you still need to record a third channel from Freeivew at the same time you would need another Freeview box of some description to record from.
  5. mh123
    mh123
    Apr 2, 2005
    696
    Offshore UK
    +72
    Ditch the VCR as a recording medium and buy a Freeview box with HDD.
  6. Heinz
    Heinz
    Aug 4, 2005
    408
    Earle Colne, Colchester
    +15
    Or get a VCR with a built-in DTT receiver.
    Like THIS Daewoo
