can i do this to my speakers?
Discussion in 'Home Cinema Speakers' started by tophellcat, Sep 30, 2004.
  1. tophellcat
    tophellcat
    right now, i have a pair of speakers that are rated at 6.3 ohms and i was wonderin if there was a way to make it so that it is rated at 8 ohms. can anyone help me out?
  2. funkmonkey
    funkmonkey
    Sep 5, 2004
    107
    16
    Sheffield
    Impossible without replacing the drivers and the crossover.
  3. tophellcat
    tophellcat
    what do you mean drivers and crossovers? and how would changing those make it possible then
  4. John7
    John7
    Aug 6, 2004
    2,381
    116
    +649
    Why do you need 8 Ohms?
    Most amps should be Ok with these?
    john7
  5. tophellcat
    tophellcat
    well, i have an older amp that has 2 sets of channels. the first is the "A" set of channels and it can only withstand 6.3 ohms by itself and the "B" set of channels can withstand 8 ohms. That is only if i am using one at a time. but, if i us both sets of channels on it at the same time, it can withstand 8ohms. and i learner in electricity class that if i were to take a 3 ohm resistor and put it in a series with a 4 ohm resistor, that you would just add them together and you have total restistance. and as i said before, i don't know if my ampliphier can handle a pair of 6.3 ohms and 8 ohms speakers when usin both sets of channels at once. that is why i wanna change the resistance of the speakers
  6. Londondecca
    Londondecca
    Dec 21, 2003
    2,100
    +103
    The difference in 2 Ohms should not interfere with the running of the speakers. I have never heard of an amp with such a specific limit of 6.3 Ohms.
    I would say that unless you are running some very esoteric gear, I would not worry about these figures
  7. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    The speakers will vary in impedance when in use anyway 6.3ohms and 8ohms will be nominal impedance.A resistor will not work with speakers the way your thinking ,funkmonkey as the only answer the crossover and driver are like a tuned circuit.
