Can I copy Mp3's on CDR to DVD-Ram
Discussion in 'Blu-ray & DVD Players & Recorders' started by Flystar, Nov 1, 2004.
  1. Flystar
    Flystar
    Oct 18, 2004
    47
    11
    Guys, anyone know if it will be possible for me to back up my mp3's and wav files that I have stored on many CDR's over to a 9.4gb DVD-Ram.
    I was going to use my Denon DHT-500SD to feed in the MP3's and wavs via optical tos link cable to my Panasonic DMR-E55 and record them onto a single 9.4gb DVD-Ram disk. If this is possible, would I have to play the tracks individually or is there some way of dragging and dropping them directly on to the DVD-Ram disk.
    :lease:
    cheers
    Fly
  2. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    Deepest Hertfordshire
    You can copy them to RAM using a PC. It would be restricted to being an archival/backup medium, though, as the E55 only plays MP3 on CDs.
  3. Flystar
    Flystar
    Oct 18, 2004
    47
    11
    Cheers. So DVD-RAM disks cannot store MP3's that can be played in a MP3 compatible audio player?
    I havn't got round to buying a DVD re-writer for my PC yet. Waiting for Dual layer technology to settle down.
    What would be the best method of storing my MP3's to play in my DMR-E55 then ?
    ta
    Fly.
  4. pentode
    pentode
    Dec 17, 2002
    109
    West London, UK
    +4
    I don't think that the DMR-E55 has a digital audio input.
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,868
    Warwick
    +2,785
    Quite correct - the E55 has no way to 'receive' your files other than recording the analogue output of your amp. By far the best way to do what you want is to purchase a DVD burner - the LG4120/4160 are very good choices - as these can be picked up for under £50.
  6. Flystar
    Flystar
    Oct 18, 2004
    47
    11
    Cheers folks. I notice now that my Denon has both but the Panny only has optical out. :suicide: Ah well twoz free anyhow !!
    Anyone know the cheapest place to by the LG Dual Layer burner. I believe it got a really good write up in the PC mags.
    Fly
  7. Rasczak
    Rasczak
    Apr 3, 2002
    21,868
    Warwick
    +2,785
  8. bobbles
    bobbles
    Hopefully with the next batch of HDD players you will be able to store and playback mp3 files in the HDD
