Can I copy more than 1 VIDEO_TS to DVD?
Discussion in 'Blu-ray & DVD Players & Recorders' started by powellcd, Jan 19, 2008.
  1. powellcd
    powellcd
    Dec 3, 2005
    I am experimenting with my Sony RDRGX350. If I record 2 separate DVDs on the Sony, can I copy them to a single DVD with my PC. I tried copying each one to a separate folder on the hard drive and then both folders to DVD but all I can see to play in PowerDvD looks like the first VIDEO_TS file. Any ideas?
    Thanks and regards,
    Chris
  2. ramjet
    ramjet
    May 21, 2006
    3,761
    +622
    no , a dvd player expects one folder with the name VIDEO_TS , and also expects one folder with the name AUDIO_TS
    what you can do is import them separately into tempeng dvd author by pegasys, author your new compilation and then burn to a new dvd from the finished article
    check videohelp.com for details
