can i convert vhs camcorder tapes to dvd disc?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by David Simcock, Jul 6, 2003.
  1. David Simcock
    David Simcock
    PLease help. Bit of a novice.
    Where can I get the old style vhs-c camcorder tapes transferred onto a dvd disc style format, if at all???????
    Any suggestions would be much appreciated.
  2. motty
    motty
    Aug 11, 2002
    try belkin usb 2.0 dvd creator it will transfer your vhs tapes to pc and i think turn it into dvd's.I am getting it tommorrow from pc world.Or avermedia has dvd ezmaker usb 2.0 that converts vhs to digital.Pinnacle have moviebox and dazzle has fushion and hollywood bridge,all can be found on the net or in pc world.
  3. David Simcock
    David Simcock
    Motty,
    Thanks for the reply.
    Is there anywhere on the high street which provides this kind of service?
    Any ideas or pointers?
    Its something I need to get converted on the hurry up, price not too much of a problem.
  4. JayX
    JayX
    Dec 10, 2002
    341
    29
    c-town
    +28
    im sure theres places that still do this, i know they used to anyway. try lookin in the backs of a/v related magazines perhaps? i doubt theres any big "chains" doing it, but bound to be stuff via mail.
  5. motty
    motty
    Aug 11, 2002
    david if you have a usb 2.0 connection on your pc i would go
    the belkin or avermedia dvd route because with the speeds of
    usb2 it is getting easier to transfer footage.
    I did read a review from some bloke i forgot where he got sonic my dvd to transfer about 19 old vhs tapes to dvd with ok results.
    Neo dvd claim there software can encode vhs to dvd alot quicker
    than other leading brands.
    Try belkins website and avermedia's websit for more details.
    But beware avermedia's product does not support certain motherboards so check the site.
    I am off to pc world to get belkins product and will post on here my results through the week.
  6. JayX
    JayX
    Dec 10, 2002
    341
    29
    c-town
    +28
    personally, i think those products are a bit of a waste of money. most things in pc world are :) it seems to be the simple mans approach and will never equal the quality of using a proper capture board and learning how to use it. also a very good vcr is handy. obviously that route is more expensive, but i always say if you're gonna do something, you might's well do it properly.
    i know people who've used standalone dvd recorders to a decent enough result, maybe you could hire one david? simplest and fastest approach anyway.
  7. DigiStuff
    DigiStuff
    Jan 22, 2002
    151
