Can I Connect Relisys Rlt1730 To My Amp
Discussion in 'LCD & LED LCD TVs Forum' started by jtfab75, Jul 14, 2005.
Tags:
  1. jtfab75
    jtfab75
    Jul 13, 2004
    810
    BRADFORD
    +10
    ........I think i can but want it confirmed before i buy it.
    thanks
  2. IronGiant
    IronGiant
    Jun 7, 2003
    62,665
    Oxford UK
    +39,846
    If it's the same model I've got I think the answer is no (but the internal spaeakers are impressive for a small TV). I will check and confirm/refute tonight.
    Dave
  3. IronGiant
    IronGiant
    Jun 7, 2003
    62,665
    Oxford UK
    +39,846
    Ah, mine's the 1720 with component in, instead of SCART which the 1730 has. Mine definitely can't do audio out. It says it has PC audio pass through but there is no output socket to do this with.
    No mention in the handbook (pdf) on their website whether the SCART is wired for audio out though. But as it has pictures of component in, in the manual, I'm not sure what to make of it.
    Dave
  4. jtfab75
    jtfab75
    Jul 13, 2004
    810
    BRADFORD
    +10
    got the tv last night and i can't connect to my amp.my old tvwouldn't either so not too upset.great sound from speakers make up for it.
    thanks for the help
