Can I connect my PC to my amp?
Discussion in 'AV Receivers & Amplifiers' started by rforey, Jan 31, 2003.
  1. rforey
    rforey
    Hi all,
    I've got a Sony HT-DDW840 system and was wondering if it would be possible to hook up my PC to the amp? I've got loads of mp3's on my comp (all legal of course ;-) ) and it'd be nice to be able to play them through the surround system rather than the crappy PC speakers. I've had a look at the back of my computer, and the sound card doesn't seem to have the normal red-and-white audio lead sockets (I'm ignorant to the technical name, sorry!) to connect it directly to the amp. Does anyone know what I need for either the PC or amp to make a connection?
    Cheers in advance!
    Rob F.
  2. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    This question may be better asked in the HTPC forum but I'll answer anyway ...
    Your PC will probably have a 3.5mm mini-jack socket on the back that you use to connect it to your current PC speakers. You need to visit Maplins or similar and buy a 3.5mm jack - 2x phono leads cable (will cost a few quid) and can connect this from the line-out on your PC (where you speakers connect) into a spare line-in on your amp.
    This is the simplest method but will be an improvement on the usual PC Speaker kits.
    Victoria
  3. rforey
    rforey
    Excellent, thanks for that Victoria. All up and running now and sounding a lot better!
    Cheers again,
    Rob F
  4. Cheng
    Cheng
    Dec 19, 2002
    374
    +6
    I'm not sure about this, but couldn't you run on a compatible sound card the optical out to the optical in on an amp?
  5. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    Yes you could run a cable from the digital output of a compatible soundcard into your amp (either optical or co-ax). I was assuming the lowest common denominator though so went for analogue connection.
    Victoria
  6. blackjack
    blackjack
    i did this the other day.
    i got a stereo 3.5 jack and 2 phono sockets along with some twin wire, soldered 2 sets of twin wire to the stereo 3.5 jack and one phono on each of the other ends, used the pc speaker outlet to a input on the back of my amp.
    i did this to as i have around 400 albums in mp3 format on my hard drive but i've only got a crappy sound card and it did'nt sound as good as a cd player, i used winamp to play them which is a good little prog to que loads of stuff mp3's into.
    cost me around £3.00 to make. abviously i'm not talking gold connectors here. :)
    BJ.
