Can I connect Bush MTT1 Turntable to Sony HT-K250 Home Theater System?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by bigdalkabir, Sep 17, 2005.
  1. bigdalkabir
    bigdalkabir
    Sep 16, 2005
    15
    Hello,
    Is it possible to connect a Bush MTT1 Turntable (or any for that matter) to a Sony HT-K250 Home Theater system? My DVD is plugged into the Coaxial Auxiliary input (as my Philips DVD625 has no optical output), which I believe is where the turntable should be attached, as the manual says this is where to attach other audio/visual components. The turntable has a built in pre-amp. Other inputs to the HT-K250 include Analog Video and TV audio inputs (red and white). At the risk of sounding a little dense, are these not the same in principal to the audio plugs from the turntable? Is there some way round it using some leads and adapters?
    Thanks for any help or suggestions.
  2. shahedz
    shahedz
    Apr 26, 2005
    10,280
    +1,217
    Hi Welcome to the forums, because the BUSH has a built in phono amp (bringing the level up) you can connect it to any analogue input (video 1, 2 or 3) just red and white phono to red and white phono socket. remember to turn the video processing off so you listen to it in stereo.
  3. bigdalkabir
    bigdalkabir
    Sep 16, 2005
    15
    Thanks for the advice. I shall try it and see how it goes. Will let you know!
  4. shahedz
    shahedz
    Apr 26, 2005
    10,280
    +1,217
    no problem, best of luck
  5. bigdalkabir
    bigdalkabir
    Sep 16, 2005
    15
    Sorry for bit of a late reply, the turntable works a treat! Not the best machine on the planet, but well worth 40 quid. Thanks for the advice.
