If the monitor has an HDMI input then yes, you should be able to use it to display whatever is being output from the AV receiver as log as the resolution and frame rate etc. in compliant with that monitors capabilities? THe Monitor would also need HDCP compliant relative to the source if wanting to playback commercial video.
