Can I Connect 5.1 system to Tv ?
Discussion in 'Home Cinema Buying & Building' started by mrdbristol, Aug 6, 2005.
  1. mrdbristol
    mrdbristol
    Aug 4, 2005
    15
    I have a Samsung WS 28W 63N - TV
    Samsung DVD E234 - DVD Player
    The DVD player has all the usuall connections - Analog RCa's,SVideo,Optical + Coaxial.
    The TV has 2 Scarts on back and Analog RCA's and Headphone on FRONT
    Can I connect a 5.1 surround system to this set-up so the sound from BOTH the TV and DVD work through the surround speaker system ?
    I dont want to use the front connections on the TV for cosmetic/practical reasons , but can't see how to do this as the TV only has scart connections on back.
    Any advise ,and info on any adapters I would need , to make this possible would be gratefully received.
    Thanks , in advance.
  2. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    Are you sure you have no phono outputs at the back of the tv?..If you haven't you can get a scart connector with phono sockets as well which would enable you to break out the audio from the tv. More important do you already have a surround amp?.Send a private message if you like I'm in your area
    Jay
