Can I connect 2 subwoofers to Denon 3802?
Discussion in 'AV Receivers & Amplifiers' started by Poskins, May 28, 2002.
Tags:
  1. Poskins
    Poskins
    Can anybody tell me if it is possible to connect two subwoofers to the Denon AVR3802?
    I have always used 2 active subwoofers with my Sony Receiver and if I upgrade to the Denon then I would really like to continue using both subwoofers.
    Thanks in advance for any info.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Even if it only has one subwoofer outlet you can always use a T piece and send the signal to two subs.
  3. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    Yes, via T-Piece works very well with my AV-A10SE, would work just as well with you 3802.
    http://www.audioadvisor.com/images/products/MCTYM2Fa.jpg
    If you can locate a Monster Turbine ones, they are great, there's very little room for a bog standard Maplins one behind the Denon.
    I had to buy from the US and got stung for Customs, Duty, Handling Fee. Bloody expensive interconnects inthe end.
    Amazon.com do sell them fairly cheap but won't ship them outside the US.
    Mark.
  4. Bonesy
    Bonesy
    Feb 22, 2002
    1,160
    Wiltshire
    +28
    ixos do a splitter cable with their low end sub cable.
    It is intended to allow you to put a sub signal into high and low inputs, but no reason why you can't use it to split the signal at the amp end.
    and it is cheap.
    let me know if you have trouble finding it, and I'll look for a link somehwere.
  5. Epoman
    Epoman
    Jan 3, 2002
    3,128
    71
    On my PC
    +85
    I got a heavy gold Puresonic one from Sevenoaks for £9.95. Does the job.
    Im
  6. Bonesy
    Bonesy
    Feb 22, 2002
    1,160
    Wiltshire
    +28
    I think the ixos one is £3.99
  7. Poskins
    Poskins
    Thanks for all your replies.You've all been really helpful.
    I've found all the products you've mentioned.You've put my mind at rest, I can know go and order the Denon 3802.
