Can I choose an Installer for Sky+?
Discussion in 'Sky Digital TV Forum' started by porker, Oct 5, 2003.
  1. porker
    porker
    Mar 18, 2002
    263
    Teesside
    +26
    Thinking of taking up the Sky+ offer but I don't want the Installation done by one of Sky's cowboy contractors.
    I would prefer to use my local sat specialists Trac Sat but I can't find any info on Sky+ on their website.Can I go anywhere for my Install or do I have to go through Sky?
    Cheers,
    Porker.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    If they are an authorised SKY installer then they can get hold of the hardware for you and install it or you can buy the SKY+ (with or without the LNB, some say it's provided others don't) yourself and pay someone to install it.
    The £1 install offer is very unlikely to be available from anywhere other than directly from SKY so expect to pay more via an independent or authorised dealer.
  3. Fernsehman
    Fernsehman
    Why not speak to the guys at Trac on Skippers Lane Industrial Estate. They supply most of the independents in Teesside. If they can't install or put you in touch with a reliable installer who can, I'll be very surprised.
    (01642) 468145 or 463748 for technical.
    Fman
