Can I change rgb to cvbs
thyristor44
Hello
I have a dm500s clone sat receiver and crt tv. I get good crisp image on cvbs output. The problem comes with my new dm800se, it only gives hdmi and pal output to the scart. Pal is blured and poor colour and tv isnt hdmi. Any way round this without buying a hdmi receiver.
thyristor44
grahamlthompson
Confused by what you mean by PAL output :confused:
The scart cable should have a composite output and may also have RGB. RGB will give a much better picture if connected by a fully wired scart lead to a TV scart with RGB support. Composite delivers the worst quality pictures there is.
drphibes
Does you tv have more than one scart socket ? If it does try the others especially scart number one and set the dm800se to output rgb.
pedro2000uk
have you tried swapping leads .. a really cheap lead can mess analogue
are you using two av outputs- phono or scart ?
it does sound like just a cheapened composite output - I've noticed some decent manufacturers are doing that & just keeping the composite as a bodged analogue to digital legacy thing & really just concentrating on hd/hdmi quality - especially TVs.
if you do have rgb output as per your title .. you can [or used to able to] get rgb to composite &/or rgb to s-video converters that usually did a very clean job if the RGB was good - not cheap though & again it depends how good the RGB is - like for like, build quality wise, they go in the order Graham has said - but it also does depend how well a manufacturer has implimented each of them & also if an stb output just doesn't like a brand of tv.
you could check the composite output voltage .. [1v p-p]- it might just be low & an AV amp will lift it- or pick up an old AV camcorder mixer & tweak it with that
thyristor44
Video output is scart or hdmi, mode in scart is pal multi or ntsc. The tv has only one scart ip and I have tried a few scart leads. I think it does sound likely that analogue output is bodged and box is mainly for hdmi. I will eventually get a digital tv but not yet. Just have to accept worse picture.
Thanks very much for all the help and suggestions.
thyristor44
thyristor44
grahamlthompson
thyristor44
thyristor44
PAL will be cvbs, ,multi will most likely be RGB.
pedro2000uk
thyristor44
do have a look for a used video mixer [ebay] - you should get one very cheap now to see if you can tweak the video output.
thyristor44
Its not only the poor colour its the lack of focus. Hdmi gives the better focus but the modes like 4:3, letterbox that are all wrong. If pal is cvbs then I have no hope as on my dm500s on cvbs the picture is very good.
The video mixers all looked expensive unless I was looking for the wrong thing.
Its a cheap clone dm800se with an integral triple tuner. Where does the scart signal come from.
pedro2000uk
I only meant this type - - but it sounds like it might not do it
