Can I change PV500's Freeview channels via DVDrecorder
Discussion in 'Plasma TVs Forum' started by StrongSilent, Jul 10, 2005.
  1. StrongSilent
    StrongSilent
    Jun 27, 2005
    498
    +6
    Hi all, this sounds like such an obvious question I'm afraid to ask it.
    I have my EH50 dvd recorder connected to my PV500 via qlink on the tv's AV4 on the EH50's AV1, direct-record etc. works fine.
    Should I be able to change freeview channels whilst watching the EH50?
    Bearing in mind the EH50 has no dvb tuner but rather gets its freeview fed from the PV500.
    I 'downloaded channels' from the PV500 to the EH50 but these were only the terrestrial BBC1-C5.
    I hope that makes sense.
    Cheers.
    H.
  2. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,621
    London
    +468
    Yes it makes sense, but you can only change terrestrial channels.
    DVB is fed into the AV1/2 whichever you have connected to PV500. The TV controls the channels unfortunately. Still not bad, pity you can''t have it all though !
  3. StrongSilent
    StrongSilent
    Jun 27, 2005
    498
    +6
    So close and yet so far :(
    Cheers Ekko.
