Can I buy a portable dvd player in the States?
Discussion in 'Blu-ray & DVD Players & Recorders' started by dvdnovice, May 19, 2005.
  1. dvdnovice
    dvdnovice
    Can I buy a portable dvd player in the States and use it back in the UK? I know I would need a multi-region dvd player but what about the differences in broadcast standards - ie we are PAL and the USA is NTSC. ? Does this have anything to do with buying a portable dvd player??
  2. danvitale
    danvitale
    Nov 18, 2004
    2,340
    63
    By The Sea
    +114
    Most portable players play both NTSC and PAL so you should be ok in that respect. I think the only thing you need to worry about is the power supply unit.
  3. Astaroth
    Astaroth
    Jun 22, 2004
    3,653
    2
    London
    +882
    It has a screen and so you have to be aware of the format - unfortuantly whilst most things available in the UK are able to do PAL or NTSC these days in the states it is much more common for them to be NTSC only.
    As an obvious thing you may also need to buy is a new transformer if it has built in rechargable battery or if you want to run it from the mains ever
