can i build video scaler with computer parts?
puppy
does anyone know if is is possible to build a video prossesor from computer parts, something like dvdo vp30 or lumegen hdp quality? need to upscale to 1024 x 1024 hitachi alis panel, dvi-d out, preferably with plenty of inputs and remote control in some kind of slim looking attractive case? i want to plug in toppfield pvr, sony dvd, and cable box, budget up tp £700.
hornydragon
you can buld an HTPC which can do some scaling but you cant feedan ALIS panel native they wont accept 1024x1024 and you cant bypass the internal scaing so its a futile excerise (doesnt mean you cant get good results or improvemnts but you can do what you can with a Pio/Panny/NEC panel)ALIS just isnt designed for PC use (wasnt designed for HC use either)
