Can I bi-wire my fronts with the Denon 3805 using multi zone outputs?
Discussion in 'AV Receivers & Amplifiers' started by TeresaTT, Oct 15, 2004.
Tags:
  1. TeresaTT
    TeresaTT
    Sep 11, 2004
    507
    Walsall
    +13
    I have just received my Denon 3805 amp and I'm trying to figure out the speaker connections.
    Currently I have a Yamaha DSP-A2 and I have my front speakers bi-wired using the Speaker A and B outputs on the amp. I was hoping to try to do the same with the Denon, but I'm hopelessly confused with all this multi zone stuff. (Initially I wanted to bi-amp, but I've given up on that as it sounds really complicated.)
    Can I use the multi zone speaker outputs to bi-wire my front speakers? Will these outputs always mirror the main front speakers? Has anyone done this and is able to shed some light for me?
    Teresa
