Can I ask a stupid question
Discussion in 'General Video Gaming Chat' started by PJONG, Nov 16, 2001.
  1. PJONG
    PJONG
    Oct 7, 2000
    87
    London
    I've just borrowed a Dreamcast S-vid cable.
    Using it with a Panasonic 32PK1, picture is in black and white.
    What am I doing wrong? There doesn't appear to be an option to set what type of output signal on the DC.
  2. rigman
    rigman
    Dec 14, 2000
    2,945
    83
    East Yorkshire
    +110
    Have you switch the TV to S-video. I have a panny 36PF10 and when you select the Scart using the AV button then the coloured button the first time it is composite and then you need to press it again to get it to S-video.
    Hope that makes sense.
  3. PJONG
    PJONG
    Oct 7, 2000
    87
    London
    Aha! Aren't forums wonderful.
    I hadn't noticed that double press when I'd switched to AV3.
    Many thanks Cossie
  4. jian
    jian
    Aug 31, 2001
    2,576
    68
    +77
    Does the S-Video cable cause the picture to shift to the left?
    Just that I have the official RGB cable and it causes the picture to shift about 1 inch to the left. Was thinking of getting an S-Video cable instead but I want to know whether the same thing happens.
  5. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,362
    Norwich
    +892
    s-video is fine , there is no picture shift.
