Can HS20 handle 1386x788 or only 1366x768?
Discussion in 'Projectors, Screens & Video Processors' started by Kane D Williams, Nov 29, 2003.
  1. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +11
    I believe the HS10, although having 1386x788 panels like the HS20, could only handle a 1366x768 signal from a HTPC. Has anyone managed to test this on the HS20? I know in terms of resolution, there is not really much in it, but if it will not work at it's panels full capability we are left with a 10 pixel border all the way around and I just don't know why Sony do not include a function that allows one to turn off these pixels?
    Can anyone please confirm if 1366x768 is the highest 1:1 mapped resolution available on the HS20?
