can H885 send IR continuously?
Discussion in 'Home Cinema Control & Remote Controls' started by Webagents, Mar 18, 2006.
  1. Webagents
    Webagents
    Jan 13, 2006
    206
    +3
    I have an IR light switch that works as follows:
    Press button - Light toggles on/off
    Press and hold button - Light brightness cycles up and down until button released.
    This light switch does NOT have it's own remote, it learns the IR from any remote you choose to use.
    I set up the 885 with a light controller device and taught the light switch the IR from it.
    MY PROBLEM...
    I want the 885 to send the IR continuously, until I release the button.
    Can the 885 do this?
  2. Webagents
    Webagents
    Jan 13, 2006
    206
    +3
    ...Yes it can,
    I called harmony support and they fixed it up for me :)
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    I guess you have varilight dimmers then!
  4. swarrans
    swarrans
    Dec 21, 2001
    409
    16
    Kent, UK
    I've got the same dimmers and I'd like to do the same with my 655 - did Customer Service tell you how they did it, or should i just ask them to do the same for me?
    I'd ideally like to use the "glow" key, but I would guess thta's not possible as it won't be set up to output IR...
    Simon
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    i would use on screen commands, "glow" is only connected to the remote backlight. check to see if Varilight is in the lighting list and if that has the correct coding for continoues IR
  6. swarrans
    swarrans
    Dec 21, 2001
    409
    16
    Kent, UK
    I've managed to get a button onto the LCD screen and it will turn the dimmer on and off, but can you remember how they managed to get it to send a stream of IR for as long as you held the button?
    thx
    Simon
  7. swarrans
    swarrans
    Dec 21, 2001
    409
    16
    Kent, UK
    I've just come off the phone with the Customer Support people (my God, they're nice!). It turned out a bit embarrassing really because he told me that what I'd done should work (ie hold down the key and it should continue to output IR) and when I tried it again it did, even though my original "test" didn't work!
    Anyway, I've never experienced such good natured and experienced telephone support.
    Simon
  8. Webagents
    Webagents
    Jan 13, 2006
    206
    +3
    Sorry dor the delay in replying.
    CS didn't tell me how they did it.
    Yes, I have a twin varilight dimmer, the buttons I had set as light1 and light2 but they did not send continuous IR.
    CS did something and just said, please update remote and test.
    It worked a treat :)
    The CS team are very polite and helpful.
    I had another issue and they fixed that as well and when i asked what they had done, they talked me through the website so that I could see what I had done wrong...
  9. Supersonic
    Supersonic
    Jan 5, 2005
    1,149
    Surrey
    +209
    I had that exact problem myself and taught the 885 the dimmer command in RAW mode (I got the little black remote with my Varilight dimmer) so it can definitely do it.
    Alternatively use the Varilight to learn an existing remote command that you don't use and then teach that to the H885 - suggest you do that in RAW mode - should work fine.
    S
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Varilight use volatile memory and if you loose mains power it losses the programming, So use the OEM remote to teach the harmony far less hassle!
  11. DemonicaEvilius
    DemonicaEvilius
    i have been looking at remote lighting for my room (ie varilight, lutron, x10), i have a 2 gang switch what i want to be able to do is set my new harmony 885 up so that i can dim down the lighting to OFF when using "watch dvd" at night ... and then fade them up when the activity is over?
    also another user mentioned bringing the lights up a notch or 2 when "pause" was pressed which i thought was a great idea :)
    is this able to be done?? or do i have just limited control of the varilights (ie would i be better off forking out for more expensive dimmers? as my budget is already stretched! lol)
    i havent got my 885 yet but so i cant really check the codes etc (altho i have done the "testdrive" 3 times under different alias lol)
  12. DemonicaEvilius
    DemonicaEvilius
    recieved my harmony the other day - soooo impressed with it!
    just wanted to let ppl know it is possible to use the 885 to create "scenes" by adding a few varilight "devices" and changing the speed settings on each device :)
    ie: 2 secs, and 3 secs etc
    took about 5 mins to do ... just thought id share that incase it helps someone else:smashin:
  13. elmbeck
    elmbeck
    Sep 23, 2002
    347
    Avonbridge
    +10
    What was the fix for the original problem (I have exactly the same thing - can't get continuous to work)?
    Do I need to call Support?
  14. Edo
    Edo
    I have just bought the 525 and like the previous post I cant seem to get the remote to send IR continuously to my Varilight Dimmers.
    I have used another remote that works with switching my lights on/off or if I hold the button down it dims them, to learn to my 525. But all it seems to do is switch them on or off ?
    Any ideas please
  15. smjohns
    smjohns
    May 29, 2006
    371
    28
    Solihull
    +31
    I have a Harmony 895 and I am looking to send a continuous remote signal for my Amp. The menu button has dual functions in that a single press activates the high level menu but press and hold for 4secs brings up the deep setup menu.
    With the default button settings for my Amp the Menu button (even if I press and hold it) only sends a short burst of IR.
    I have tried recording a new button using the RAW mode but when I press and hold the button although it is continuously sending IR it seems to insert a gap and my amp just sees it as me pressing and releasing the button continuously.
    Any help will be greatly appreciated.
    Si
  16. swarrans
    swarrans
    Dec 21, 2001
    409
    16
    Kent, UK
    In my experience the support staff at Harmony are incredibly knowledgeable and helpful so I'd give them a try.
    Simon
  17. GSXRMovistar
    GSXRMovistar
    Jul 26, 2004
    87
    11
    +3
    I've got the same issue with sending continuous IR to a set of varilight switches, have any of you been given the details of what you need to change or can this only be done by customer support?
    Thanks.
  18. smjohns
    smjohns
    May 29, 2006
    371
    28
    Solihull
    +31
    Aye contact customer services and hopefully they will be able to sort you out. Had a similar problem with our Arcam amp and a press and hold menu function.
  19. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    If you want to get really tricky look at RAKO need a rako module wall plate and RAVIR unit cost is £300 not £30 but you can have scenes and select the scens as part of each activity as well as control the light level with up and down if you have more than 1 or lighting circuits its well worth a look.
