Can DVI-HDMI cable be used to connect PC to projector?
Discussion in 'Projectors, Screens & Video Processors' started by wizard of oz1, Jan 13, 2008.
  1. wizard of oz1
    wizard of oz1
    Feb 3, 2005
    309
    Gillingham
    +29
    I have tried to connect my Geforce 7900 GTO graphic card to Sharp Z3000 projector via DVI-HDMI cable but I have no response from the projector. I am using nview and software recognize it (Sharp) on dualview but when you switch on single view to view Windows on projector, I do get no reponse at all. VGA to VGA connection works fine but obviously I would like to use pure digital connection to maximize its quality. Is there anyone who has any idea sorting out this problem?
    Thanks.
  2. chenko
    chenko
    May 14, 2007
    63
    Yes it can, but it depends on your cards DVI output.
    Having a quick look, I cannot see anywhere it shows that card as supporting HDMI(or HDCP) for your card...
  3. sapper
    sapper
    Jul 20, 2000
    2,258
    Southgate, North London
    +145
    I am not sure if this helps...
    I currently connect a fuji 58 series panel to my HTPC using a DVI-HDMI cable.
    The HTPC is running AnyDVD in the back ground and Ihave had no obvious problems connecting my HTPC to the plasma to watch any thing, be it blu-ray, HD-DVD or normal DVDs
    Adrian
  4. spooney
    spooney
    Oct 2, 2006
    2,252
    Seyring
    +204
    As you stated your graphic card driver will recognize the pj as part of the HDMI handshake. When you switch to single view you must make sure the proper resolution and refresh rate is set, e.g. [email protected] or whatever is supported by your pj. This does not happen automatically except your pj is set as primary display and you do not allow unsupported resolutions.
    Please note: You won't be able to display HDCP protected content which are all purchased media.
  5. wizard of oz1
    wizard of oz1
    Feb 3, 2005
    309
    Gillingham
    +29
    I have tried every resolution and refresh rates. I have also set the projector as primary display however I get no picture at all. :confused:
  6. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    Is it a faulty cable from a dodgy ebayer (banana something)
    I have a DVI to HDMI cable from ebay that didn't work.
    PS
    Ignore what Spooney says about HDCP, it's totally wrong.
  7. sapper
    sapper
    Jul 20, 2000
    2,258
    +145
    This is not strictly true....
    WEll okay, if you buy or build a HTPC and attmept to play a non region 2 SD DVD or a American Blue-Ray disc the chances are it will not work.
    But if you invest in some software, for example AnyDVD and instal that on your HTPC, then it will over come the regional coding issues.
    I was also going to sufgggest can youtry another cable or adapter, or borrow one?
    Adrian
  8. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    Sorry, but this is also totally wrong.
    HDCP is nothing to do with region coding, HD-DVD has HDCP but no region coding, Blu-ray has HDCP but only about 10% have region coding. AnyDVD does not work on HD/Blu disks. AnyDVD HD removes HDCP for HD/Blu disks but is unlikely to be able to do anything about region coding on Blu-ray disks (but you can change the region of the player as many times as you like anyway).
    from wiki
    "High-bandwidth Digital Content Protection (HDCP) is a form of digital copy protection developed by Intel Corporation to protect digital audio and video content as it travels across DisplayPort, Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI), Gigabit Video Interface (GVIF), or Unified Display Interface (UDI) connections. The specification is proprietary, and implementing HDCP requires a license."
  9. ShanePJ
    ShanePJ
    Well-known Member AVForums Sponsor
    Jun 20, 2006
    2,652
    Unit 5 The Sidings, Bacup, Lancs, OL13 9RW
    +682
    Hi wizard of oz1
    Seem as though you are having some problems with connecting your Sharp Z3000 to your Geforce 7900 GTO.
    First big question is how long is the DVI - HDMI cable!
    Have you the latest display drivers for your Geforce 7900 GTO and what is your operating system! I.E. Windows XP, Windows Vista, Mac OS/10?
    Regards. Shane.
  10. ChrisA
    ChrisA
    Jul 14, 2002
    189
    Suffolk, UK
    Hi Shane,
    I note your comment about cable length with interest. I'm looking to do a similar thing and connect my PC to plasma with a DVI/HDMI cable but need to run a 7.5m+ length - what are the restrictions on length?
    Regards
    C
  11. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    when you plug in a working DVI to HDMI cable to the PC/PJ with no other displays connected and you turn on the PC you will see the bootup screen if you have a working cable.
    No drivers, no fiddling with resolutions, no operating system needed on the PC.
    How hard is that to do?
    It doesn't matter how long the cable is, if the cable is working.
    It doesn't matter what drivers you have.
    PS. there is allegedly one very old model rptv where this is not the case.
  12. ShanePJ
    ShanePJ
    Jun 20, 2006
    2,652
    +682
    Hi ChrisA
    The Cable lenght should be fine @ 7.5m
    We've tried plenty of projectors and found that some cable do fail maybe not at first but they seem to in the end. We have to very populars cable built into the wall in our demonstration and unfortunately they are dead after around 6 months usage.
    If you are running 720p you can get away with some very long cables but spending money on the right cable helps keep the cost down in the long run!
    1080p and this is different regarding length and problems can be had with the amount of data being transfered over this distance. Unfortunately 1 and 0 do get lost which is not ment to happen.
    As for the drivers. We have found that it does make a difference.
    Regards. Shane.
  13. wizard of oz1
    wizard of oz1
    Feb 3, 2005
    309
    Gillingham
    +29
    Hi, Shane
    The cable is 6 meters long (Monster Cable which was over £100). I have downloded latest nvidia driver and operating system is XP. On nview I can see two display 1. Iiyama CRT monitor 2. Sharp HDMI so I think graphic card recognize the projector however projector does not respond the signal (neither in single view nor in dual view). I checked Sharp's manual and found out that ' projector does not support DVI-HDMI connection':mad: I think I will give up and use VGA connection.:thumbsdow. But thanks for all your responses:smashin:
  14. ShanePJ
    ShanePJ
    Jun 20, 2006
    2,652
    +682
    Hi wizard of oz1
    Sorry to hear about that.
    Regards. Shane.
