Can Cyrus 3i work as a Power amp?
Discussion in 'AV Receivers & Amplifiers' started by t-c, Aug 7, 2005.
  1. t-c
    t-c
    Hi...
    I have a Cyrus 3i integrated amplifier which is no longer being used.
    I need a power amp for a new AV system.
    Does anybody know if it is possible to use the Cyrus 3i as a power amp?
    At the moment i can turn the Cyrus 3i volume up to 50% and use any of the inputs for a crude imitation of a poweramp. Im slightly hopeful in that there is a VI input for use with the Cyrus AV processor of the time....
    Its old kit but a shame to see it gather dust if it can still be useful.
    Thanks in advance.
    t-c
  2. aerobic247
    aerobic247
    Jun 29, 2004
    180
    East Kilbride/Glasgow
    +13
    Hi t-c i have a Cyrus AV system
    Cyrus AV5 processor
    Cyrus Q power Rear Left & Right
    Cyrus 3 Front Left & Right
    Cyrus XPA Center
    Cyrus recomend that if you turn the volume of any integrated Cyrus amp to 2 o'clock
    your amp will be gain-matched to that of any Cyrus Power Amp
    as shown in page 11 of this manual manual
    The automatic gain-matched VI input is only available in the Cyrus 5 and above.
    All this is, is when you select the VI input and have ether a Cyrus AV5 or AV8
    conected the volume will turn up to 2 o'clock automatically.
    I hope this helps.
