Can Component connection change screen size?
Discussion in 'Blu-ray & DVD Players & Recorders' started by jedi-jae, Mar 14, 2006.
  1. jedi-jae
    jedi-jae
    Sep 23, 2005
    586
    +11
    I've always had my DVD player hooked up via a scart cable, and depending on the ratio of the DVD content my tv would switch between 16:9 and 4:3
    I now have my DVD player connected via component cable for a better picture, but have noticed that my tv no long changes size automatically, I have to manually change it.
    Is this normal with component, and is there a way round it?
    Thanks.
  2. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    It's normal for component. You'll have to change the aspect manually. S-video connections also have the same issue.
    The aspect switching signal is carried on one of the pins of a scart socket.
